So IndyDan, did you get a chance to work on the Team clutch this past summer like you said you wanted to?
Easier to Just call Dan.
Hey you 900 Polaris guys check out the thread I posted on " all polaris" entitled "Penicillin for Snowmobile Cranks". It's a live demonstration of a Polaris 900cc motor that has been balanced. I can now do every 900cc Polaris with you just sending your primary clutch and I can do an external balance of the motor for 350.00.
Mr, you need to be careful when you start telling people they don't know how to tru-cranks.....And that you are the higher then thou, And have just figure this all out.
I have news for you, I just watched 2 of your videos and you do not have any idea what your talking about in either of these 2 vidoes.
#1 - you do not know how to, chk or tru a crankshaft ( and I can prove it )
#2 - your TRA video is retarded to say the least. .025 thou run out, ( on the moveable ) Then you added... ( For example ) I understand trust me. 20 plus grams. That clutch is completely junk. In 20 years I have NEVER seen a OEM clutch that needed 23 grams removed in one place.
You need to be careful before you go slamming the OEM's like they pump out nothing but junk. Your runout verses out of balance is stupid to say the least.
Your 1977 balance paper is nice and perfect balance is also nice.... and I am not saying you can't balance things. But your examples and explainations are way out to lunch.
Now don't go getting all pissy, Think long and hard because I promise you this I can explain where your wrong in so many ways and I can do it in a way that the workin man and the engineer can all understand.
I normally don't say much on here anymore, But when someone starts barking they got it all figured out and I see within seconds that they surely do not I have a problem with that.
Dan
Thanks for the Explanation Dan. That does make sense completely about the checking crack for true. I never though about the fact that a clutch puller goes into the hole in the end of the crank and causes marring.
It still seams to me that what you are saying is the cranks lack the proper mass and that what you did is add mass to the TM3 to make it run smooth. Is that correct?
If that is correct than shouldn't doing what he is doing have some beneficial effect at reducing vibration just as when running the Primary with the flywheel for the starter seems to?
One big problem I see here I think Dan has mentioned is you cannot balance a worn out clutch so without going through the clutch first and making sure it is perfect, how can it even be balanced at all?
You could balance it and recheck it 30 minutes later and it would not show as balanced if it has worn out parts that allow things to shift.
IndyDan
I'd like to address one of your claims or assertions (see below)
The clutch was not junk, it had been just cleaned, bushings replaced (even a little tight for my liking), clutch kit freshened with new springs, slide channels/towers were polished. It had not recieved any damage, that I know of, and was in Good working condition.
I would also like to say that comparing the castings of these clutches over the years, they have gotten alot worse. Build it quick and cheap seems to override quality and longevity.
I can't speak to the Polaris crank issues and blowing belts, but Skidoo has replaced my engine a couple of times, all relating to bearing issues. Now for about the cost of Boysenn Rage Cages and Wings (That I saw no differance or increase with) I can try to keep an engine for more than 3k miles, not too bad....
To me as an engineer, who deals with suppliers of Jet Engine parts and have spoken to bigger brains than mine, it makes sense to remove as much vibration as possible and reducing unbalance is critical.
I'd gladdly post pics of the clutch for examination, or you check out the thread over on DooTalk.com in MachZ Section.
Later
GutZ
Dan
Sorry it's taken so long to respond, we just got 24 inches of Wet Snow! But we still had leaves on the trees, so they all came down and we have no power or heat or cable....
I believe that the ".025 thou runout" in this case is not an axial displacement or machining distortion, but a displacement caused by the unbalanced force moving the machines/balancing equipment by that much as the clutch spins. Once balanced the clutch ran smooth, to me, in the video. No amount of balancing can remove "Mechanical" runout. I believe just this balancing will save me huge Dollars down the road.
Maybe Joe can elaberate more.
Thanks
GutZ
