Reverse won't work at all, 2013 SBA
P
phatboy07
I just finished doing a fix kit on my 2013 SBA. MTNTK kit with the new Vforce 3R reeds. Sled started up fine but idled poorly after a few min (seems to be common with the new 3r reeds until they break in). Sled warmed up ok no weird issues other than the idle and reverse will not work. I press the button and nothing happens, the sled just keeps idling , it doesn't do anything. I followed the wiring back and it is plugged in (under front cover by the handle bars). Is there a plug I could have missed elsewhere? TPS? Sled runs great, runs strong good throttle response, put 100 miles yesterday on it. Idle still off and no reverse (button does nothing)
PULL THE V FORCE REEDS OUT AND PUT STOCK REEDS BACK IN OR YOU WILL NEED POWER COMMANDER TO REMAP FUEL TRIM FOR V FORCE REEDS JUST WENT THROUGH THIS WITH MY 12 DOING THE EXACT SAME THIS WITH THE FIX IT KIT. I SWORE I SCREWED SOMETHING UP UNTILL I JUST REMOVED REEDS AND PUT STOCK BACK IN AND RUNS GREAT NOW.
if the tps is miss-adjusted or faulty you can get those symptoms!
my sled would not reverse, ran like a champ otherwise and it was the tps sending values at idle saying i was holding the throttle! doesn't take many mV from spec!
don't see why changing reeds would mess up the ecu since all the air/fuel measuring takes place before the reeds? reeds "simply" does a check valves work?!
someone who knows- please enlighten me, an ignorant fool! :)
PULL THE V FORCE REEDS OUT AND PUT STOCK REEDS BACK IN OR YOU WILL NEED POWER COMMANDER TO REMAP FUEL TRIM FOR V FORCE REEDS JUST WENT THROUGH THIS WITH MY 12 DOING THE EXACT SAME THIS WITH THE FIX IT KIT. I SWORE I SCREWED SOMETHING UP UNTIL I JUST REMOVED REEDS AND PUT STOCK BACK IN AND RUNS GREAT NOW.
Don't need to Yell Jason!! lol!!
Figure ur lights out yet?
