I added reverse lights to my trailer to help illuminate while backing in Alaska's famous winter darkness. We are always driving out to our riding areas and back home in the dark, so I added these lights to help in parking after a long day (the ramps block the truck reverse lighting). Thanks to 94fordguy for the idea and help on installation.
Layout the lights so they will line up with the factory tail lights
Drill 2-1/2" holes with a holesaw (be carefull so you don't damage wiring)
Cut between holes with a sawzall (be carefull so you don't damage wiring)
Fish wire between rear of trailer and tongue. Connect wire to the new reverse lights and tie into existing ground from tailights
Connect wire to the center reverse pin on 7 wire plug
Installed lights
Light test
I also added tall reflective markers on the rear trailer corners to help see where the trailer is when backing. Snow is falling on the mountain peaks up here, time to start getting ready for another season! Anyone else have any ideas for an open trailer that they want to share?
Installed lights
Light test
