http://www.avalanche.ca/cac/bulletins/latest/monashees-selkirks
http://www.avalanche.ca/cac/bulletins/latest/south-columbia
Keep yer head up out there, snowpack should be quite interesting for a while with a big new load on it.
So I don't have a ton of mountain experience, your saying if it does snow all this fresh snow they are calling for it'll be bad avalanche conditions ? Or are the conditions already bad.
High = Bad.
Buried/preserved surface hoar and facets within the snowpack = likely to stay Bad for a while.
Considerable with buried surface hoar and facets = Still Bad. Natural activity might slow down, but rider triggered still very probable.
Moderate ESPECIALLY with buried surface hoar and facets = Can be bad cause most toss caution to the wind when it hits Moderate. Sleds are big triggers.
If you dont understand the avy report, especially now when its BRIGHT FREAKIN RED... Good luck out there. Take a course!!!!! This is not a normal BC snowpack and likely will remain as such for a bit.
I like the book on salt on the table explanation, and like salt under a book on a table it will likely remain until something moves it or washes it away.
If refer the condition to be Ball Bearing. And there is a simple home test you can do from the comforts of your living room.... Take a smooth hard back book and pour a slight amount of table salt on the hard cover of the book while slightly tilting the book simulating the angle of a mountain slope. This simulation demonstrates how volatile the snow pack will be on all aspect at Revy. Be safe if your going
DPG
