Rev Nun interchange??????
Hello will the front Nun interchange on all years of Rev Chassis`s??
I purchased a 03.5 Summit chassis minus front nun, that has a VE drop and Roll Chaincase kit installed with the jackshaft in the tunnel, has the VE chaincase belly pan protector, VE multiple hole Drop bractets, and has 151 cooler install with VE tunnel extension.
and I am dealing with a guy on an 06 440X front nun and am pretty confident it will go on to the chassis I purchased,
I have a series 4 159x15x2 1/8 track that is on my chassis now and am going to swap it all over the the D&R Chassis till I get me a 163x16x2.5 that I might cut the lugs down to 15inch I plan on installing later on. along with some AI chromoly 37inch control arms, but for now I will swap over my stock arms that I have narrowed to a 36inch stance now that work good, I just want some lighter weight arms, be nice if I could buy a set of 36inch front arms
What do you all think, any info will be apprectiated
Thanks, Wildcard
[/IMG]
Should work
I don't know about the half year model, but 04 - 07 Nuns are interchangable. They updated the Nun in 07 when they started adding the reinforment plates. The one I have is the update, but its still on the chassis and I'm gonna keep it with the bulkhead/tunnel. This is the way I'd prefer to sell it.
I purchased the 03.5 chassis and its the same as the 04 summit cause chaincase is same length as my 04 as I see so far, the 03 Revs or first editions as I under stand have the same shorter chaincase that the ZX has
the Rev Summits possible have longer chaincases. I figured they are all interchangeable, I`m purchasing an 06 440X front nun with all the extra racing bracing in it and I`m going to make my own LH, RH side bulkhead braces and extend back far enough to but up against the VE drop and roll template plates that are riveted to the bulkhead for the Drop and Roll chaincase kit, Pretty Sure when this is done I will have one strong Chassis,
my Snoweliminators from my 04 will be the only extra addition to this Mod Chassis for now till I get a 163x16x2.5 track to install cause of the D&R kit.
I would really like to install an aftemarket VE Custom rear tunnel / Bumper kit or the whole VE or Fabcraft Mountain tunnel but that can come later, since everything else on this chassis is VE would like to make it a Complete type VE modded chassis
Wildcard
