Rev Fuel tank Question???
I'm doing a mid mount turbo conversion on my Yami sled which requires the use of an 04 -06 Rev fuel tank. Are all these tanks basically the same cause I need to order a seat from Boss or someone and I'm hearing from some guys there may be differences in the tanks. Basically I just need to know if I can just order a seat and it will fit the tank.
Thanks
M5
I think so..... there is a 440 rs tank that is only like 5 GAL tank....... some are black and some are clear/white. I also think the RT chassis is the same tank? Not 100% sure
04-07 summit revs should all be the same size. The ones from the x models are generally clear and dont have the fuel gauge in them. The ones from the 600 SDI models have a fuel pump in them, so I am not sure you want/need that.
I am not sure of the size difference compared to the mxz's or the RT platform revs, so you may want to look into that separate.
You can always check the part numbers on the microfiche either on the ski-doo site or at Ronnies mail order here...http://www.ronniesmailorder.com/fiche_select1.asp?cat=Snowmobiles&mfg=Ski-Doo
good luck
Joe
There were some differences under the tanks as the REV Summits are plumbed differently than the standard REV models but that wouldn't affect how the Boss seat fits over the top so no worries.
Have FUN!
G MAN
Does anyone know specifically what plastic these tanks are made of? I may need to do some repairs to mine...
Fack
Thanks for the fast replys. I'd have been waiting for a month on the Yami forum. The tank I have purchased but haven't recieved yet is clear so I think it must be an X tank.
M5
Fack
HDPE. If you intend to plastic weld (only good way to repair them) then make darn sure no more vapors exist!
Have FUN!
G MAN
