rev electrical help
ok so none of the electrical in my rev will work. hasent worked sice i bought it. any solutions? it starts and everything nd goes but lights arent turning on. i dont have a controler thing thats usually mounted on bars. let me know what you think.
oh and it has been under water atleast once haha
Do a search on Skidoo relay, if you cant find it here go over to DooTalk.com and search, there is a TON of info about what relay and electrical causes that.
This is most likely your problem.
You can get a much less expensive part at any auto parts store so if it's not the problem you're not out more than $7.00.
SkiDoo sells the same thing for @ $30.00 and up.
If you've lost your headlight, all guages, Grip warmers, it's prolly it.
Search relay here and DooTalk as suggested and you'll find it.
Very common problem.
But if somebody hacked up your wiring from the bars you might have bigger problems and your better off taking it to a good dealer.
yeah ive tried that and still nothing and my relay works im my gf's rev so thats not it. im workin on swapping voltageregulators. anybody else got ideas? nobody on dootalk has been able to solve it yet
im not sure if they do but how would i check that and where is the stator located?
I'ts behind the recoil starter and flywheel.
There IS a test you can perform with a multimeter but I would suggest you get the shop manual if you decide to do it yourself.
E-Bay has many folks selling them for anywhere from .99 to $15 on CD.
according to my mathematical calculations, the hypotenuse of your boggle will result in a new handlebar setup.....hahahh jk.
