Rev Chassis tweak
A buddy clipped a tree with the right side front suspension on his 2007 xrs on the weekend. Nothing broke, but the lower a-arm mounting points are bent significantly back and there is a wow in the bulkhead infront of the stinger. Question is what, if anything, can we do to get the suspension mounts back to where they were and will the wow in the bulkhead affect anything? What does a new bulkhead cost? Can the suspension mounts be cut off and new ones welded on?
Thanks for any info.
You need to replace the "nun". Probably about $250 fix to be like new. Add the MXZ brace behind the silencer to get that part straight and strengthen. The "nun" comes with all the a-arm mounts, just need fasteners and a couple evenings in the shop.
