Replacing/Upgrading Front Shocks '07 D7 RMK
MORSNO
I'm considering replacing my front shocks with a coil over shock from the factory Walker Evans Airs. I want to go to a coil over shock for the security of a spring if the seal blows, especially in the really cold temperatures, and the better ride throughout the shocks compression.
I've narrowed down my choices to either the Fox Zero Pro's from Carls http://www.carlscycle.com/eshopprod_cat_2438-19673_product_251369.Zero_Pro_Ski_shocks_2005-2009_.htm
Or the Walker Evans Clickers from SLP http://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=3&catID=47&productID=1298
I'd like to hear opinions on the performance, ride quality, and durability of these two choices. Thanks!
I'm holding off on replacing the track shocks until I see if the 2011 Pro Ride RMK skid with coil over shocks is a cost effective option.
Fox Zero Pro
I went with the Fox Zero Pro's from Carl's. I like them alot, got rid of a lot of the diving. I have the 100 lbs springs, you can get 110 lbs also.
I also went to the heavy sway bar they have and Simmons skis.
