Replacing cam buttons ?
On a 02 Mountain Max, how do you remove the cam buttons (what the helix slides on)? Are they pressed in? Mine have a flat spot on them and I need to replace them.
Yep, pliers or snips grab and pull. If they are stubborn and break off, drill a hole in the center and run a sheetmetal or wood screw in the hole and pull on that.
I took the pliers to them the other night. I cracked a cornor off, and they did not budge. I figured I better ask.
Might have to drill mine out. Thanks
