replacement throttle
The flipper doesn't allow the cable end barrel to rotate and match the cable angle.
(My observation anyways)
(I had a munster)
Keep an eye on it.
Seen reports of a few breaking.
(I had a munster)
Keep an eye on it.
Yes thats happend to me once also. Thought it was a branch that hit it.
Guess i gotta switch back then :/
Carve a little plastic out in the flipper so it can rotate?
I quit using it because I preferred the thumb throttle.
No reason you can't make it work.
So I was thinking about this the other day and I'm sure theres a simple answer that I havent thought of. But wouldnt an average ATV style thumb throttle solve the woes of snow getting jammed in between the flapper and the return? Since the cable on an atv style one is usually enclosed and the thumb throttle hangs below... just a thought.
