I run à 2011 kit on my 800 pro, ive read about some oilpump failures and would like To be on the safe side. Wheredo i get à replacement pump?
i run 2 and a gauge. if a pump fails my trips not ruined. peace of mind is worth a lot to me way out in the back country
Depends where you are pulling the power from. The Walbro pump from Boston Or Justin is great, and a very reliable pump. 2 is probably overkill IMHO. Any problems with these pumps come from crap in the oil.
Oil pressure and boost gauges should be mechanical. No power needed, unless you want them lit.
Are you running the headlight?
I thought running no headlights did nothing for the DC voltage system that oil pumps and all of the other turbo related stuff draw from? I think someone was actually trying to test if the headlight removal actually helped out or not, but don't remember the outcome.
What year is your sled?
How much boost you going to run?
