replace or patch belly pan?
Snowbird11
i'm looking for some ideas to fix this:
any ideas or should i start looking for new plastics and a way to rivet it back together?
btw, anyone have an aftermarket bumper they'd care to part with? mine has been in need of change since last season.
If you don't want to do the belly pan just patch the hole and then cover it with a skid plate. good luck!
I recently saw somthing that might work on ebay for not alot of money
sorry no link but I was looking for a left fender and saw a belly pan not sure if it was right year but might be worth a look
I have a whole front end plastic left and right side and Bumper and skid plate off of an 07 700 that should rivit right on for you and i have a couple hundred rivit. I will be in tremonton ut on wednesday or if you need it sooner give me a call 208-681-4817
didn't mean to jump in before snowbird....... absolutely let him? have first shot at all of it just thought I would throw it out there if snow doesn't need the left front I would love to work it out with you
Not a problem I'am just not sure what he needs and doesn't need but you will for sure be #2 in line for any or all parts.
Have you heard anything from the bird? ID.....
I am still interested if you want to part with the left front
Brad
I did talked to him late tuesday night he want's the whole front end.
I will check on a couple leads I have for you on Friday all you needed is the left fender correct. That would be the clutch side setting on the machine.
Let me know Thanks.
Bill
that is correct clutch side..... sitting on machine is left side
I appreciate you checking around for me........If you know someone that has one they want to part with great if not no worries
BK
just pulled the belly pan on my sled and its not a big job. Should take less than 30 minutes to remove.
Pull your pipe and then its just a matter of drilling 10-20 rivets and 2 plastic clips on each side
