Removing the arm from oil injection pump from throttle body?
snowmanx
Can't quite figure it out, also, to remove the air box and bodies, do I need to remove the oil resevoir? Thanks
to remove the arm just pull/pry towards the clutches, its just ball joint type fitting, it will just pop off and no you do not have to remove the oil tank, once you have the front piece of the airbox out ( 1 screw in the very nose of the sled) then just grad the remaining peice of the airbox from the front and pull, (the warmer it is the more flexable and easier it is to get out), after that there is enough room to get the throttle bodies out, but remember there will be 2 coolant lines attached to the bottom of them,(unless they have been bypassed, depending on who put your sled togther) make sure to disconnect them, hope this helps.
it just pops off like a ball socket,....remove and toss the e-clip if it has one, i simply wedge a flat head screw diver in there and pop the thing off
on the topic of removing the oil injection res....well this is a huge reason i was more then glad to remove it and premix, its waaaaaay too much work with that oil bottle in the way
Ya I got her guys, just like ya said. Just wanted to make sure as it sucks when you pry on something that's not supposed to b pryed on!:eek: LOL
