Removing Electric Start on a Pro
U
Mar 9, 2015
5
Has anyone removed the electric start, battery, starter, solenoid, wiring and circuit breaker? If so did it cause any issues or can I remove everything except for the ring gear on the clutch without any worries?
Thanks for any help.
sledhead_79
617
366
Wyoming
You selling your ES? I might be interested in swapping clutches and buying kit from you.
Phat Cat
134
35
Lacombe, Ab
You can't bolt a ring gear to a non ES clutch. No bolt holes. Like Polaris900rmk said sell it as a package. I was looking for a used kit last year but couldn't find anyone that would swap clutches. I ended up buying a new kit that includes a new ES clutch.
Sent from my SM-G900W8 using Tapatalk
U
Mar 9, 2015
5
Removed everything but the sled is throwing a diagnostic code 10, which is an abnormal rate of voltage change to the throttle position sensor. Anyone have any ideas on this code. Read one guy that said his was because of bad gas and that fresh gas fixed the issues.
Sheetmetalfab
7,957
6,720
Check your ground?
