P
predatorr03
I don't know if somebody did this already but i found it worked pretty good!
i had big deep scratches on my bellypan and found a little trick to make them almost dissapear.You need a heatgun and some sandpaper (beer is optional).I used a 80 grit beltsander belt but 120 to 150 might work better.you simply heat your plastic with the heatgun set on hi until the surface gets softer and lightly roll the sandpaper over it.For the lighter scratches,they just kind of blend in because of the heat.Be careful not to overheat and melt or distord your plastics.You could start underneath to get the hang of it.The only problem is that the plastic gets a little shinier where it was heated.
