C chralle Member Premium Member Aug 26, 2016 #1 Hi I removed the e-start from my sks. Do i need to rebalance the primary clutch after I removed the "starting gear"? Skickat från min D5803 via Tapatalk
Sage Crusher Well-known member Lifetime Membership Aug 26, 2016 #2 I ALWAYS have my Primary balanced .... regardless My 16 Axys was way off- so I would for the piece of mind and your crank will thank you for that....
Sage Crusher Well-known member Lifetime Membership Aug 26, 2016 #4 .................And that goes for any make/model of sled- Spinning at a Min of 7,500 and up will make you consider a balance.
AKFULLTHROTTLE Well-known member Lifetime Membership Aug 29, 2016 #5 Usually you do not remove the gear, just remove everything else.
Sage Crusher Well-known member Lifetime Membership Aug 31, 2016 #6 AKFULLTHROTTLE said: Usually you do not remove the gear, just remove everything else. Click to expand... Yep.. agree-^^^^ and...... it will throw the clutch off balance if you remove it ( gear) for sure.
C chralle Member Premium Member Sep 1, 2016 #7 Okej then I'll just leave it on! Thanks for the response! Skickat från min D5803 via Tapatalk
