Reflective heat tape
Vertical-Extreme
Where is eveyone getting the reflective heat tape for taping the inside of your hood or whatever when you put twins or taller exhaust on ? all i can find it the roll that is the same width as a roll of duct tape there has to be wider stuff out there!
Reflective Tape
I picked up a really long (I think 100 yards) from the local Polaris shop for $18.00. They also had some sheets of it, if that would work better for you. You could also pick up rolls of aluminum tape like others have said from Walmart, Ace, ecetera.
I ordered DEI-brand heat screen radiant matting for the inside of my hood and DEI Cool Tape for my hoses, wiring, etc. The matting is good for radiant heat up to 2000*F. I cut it to fit and glued it to my hood with high temp silicone. Here's a link to DEI's website :http://www.designengineering.com/products.asp?m=sp&pid=26
By the way, I see you're from Alberta, so you can order these products from Canadian Tire. They're in Can. Tire's performance and accessory catalogue.
