If your reed valve boots are severly cracked to the point where you can see light through, can that prevent fuel from getting to the carbs? Since it needs vacuum for the fuel pump to operate. I am working on a 02 summit and it is getting no fuel. I have to replace a piston and rings in it yet but would like to get it running before i disassemle the engine, that way I can check the crankshaft seals.
