Does anybody make a reed cage mount that will hold up on these sleds. I bought a set of the kimpex and only got 2 rides before they cracked and that was with insulated heat tape. thanks
mounts all look good, sled only has 400 miles so everything is still real tight. thinking its more of a heat issue, picked up a set of the updated mounts and gonna try them with some heat tape and maybe a heat shield. the kimpex boots i bought through dennis kirk and they are refunding my money as soon as i send them picsSounds like a possible movement issue. Throttle bodies/Air box loose? Motor mount broken? Have seen good results with the Kimpex set any warranty?
i did end up building a heat shield when i had it all apart. mine is a bit smaller and i also added heat tape to the top of the shield.I went with a piece of 5x10 aluminum plate. Not sure if it will act as a heat shield or heat sink and heat the carbs !! $5 !
