Redline
sledneck_03
anyone checked out www.redlinesnowmobiles.com lately? its owned by a different company and there is a log in. Before it took you to their dune buggy. Anyone know if that did well or if they got bought out, there is a copyright 2003-2009 by Amity Technology. My firefox tab says Amity Technology The global leader for sugar beet equipment. haha
Here is info from Amity Technology, they look very capable of making a sled if they have the know how and it looks like they have the wallet. Companys like Tison performance didnt last but look at CR Racing and others, sled modding is back, maybe there is a market for Redline this time.
Capabilities
Laser Cutting: Flat
* Bystronic 4020 4 x 2 meter capacity with dual pallet shuttle system 4,000 Watt.
* Mild Steel: up to .75"
* Stainless Steel: up to .375"
* Aluminum: up to .250"
Laser Cutting: Tubing
* Shape: < 130" L to > 130" L
* Round: 12.5" Dia x .50 Wall to 5.5" Dia. x .50 Wall
* Square: 8.0"x 8.0"x .50 Wall to 4.0"x 4.0"x .375 Wall
* Rectangle: 8.0"x 8.0"x .50 Wall to 5.0"x 2.0" x .375 Wall
Fabrication
* CNC Folder 216-40/10 Fasti w/auto crowning, precision, segmented tooling. Specializes in larger panels in low/medium volumes. 4 meters long x 10 mm" (.393") mild steel
* Cincinnati Formmaster II precision 88 ton 8' bed CNC XY controls
* Press Brake 135 Ton 12' Dia-Acro
* Shear .375" x 120" Hydraulic - Pearson1 NC
* Hyd-Mech horizontal bandsaw
* 1 CNC Marvel 81-A PC vertical bandsaw with auto-tilt
* Other misc. punch presses, notchers, radial arm drills, etc.
Welding
25 MIG wire feed stations with 4 OH crane bays for 5 ton, 3 ton, 2 ton, and 1 ton parts respectively. Excellent Jigs and Fixture design & build for quality assurance.
* Liquid paint system with 250 ft. 6" monorail capable of handling parts up to 3 tons, 20' L x 8' W x 11' H
* Phosphate Wash Station
* Gas Infrared Cure Oven
* Zinc & chrome finishing, powder-coating, heat treating (available locally)
Assembly
* OH crane bay hands off directly from paint line to 5 flow-through assembly bays serviced by 3-ton OH bridge crane
* Plus two 1-ton jib cranes.
* Shipping and loading bay serviced by 20Ton OH bridge crane.
* Flexible for nearly any size product.
Machining
* Haas VF-5 50 taper 30 HP VMC 52 x 26 with 4th axis
* Mitsubishi 50 taper VMC 42 x 26
* Mori-Seiki SL25 CNC turning lathe 2.5" spindle bore
* Lodge&Shipley PowerTurn large spindle bore lathe 8.875" through-hole x 96" bed
* Clausing Engine Lathe Manual 15"
Engineering/CAD
* Solidworks CAD, Cadkey Solids
* Read most drawing formats
* Five Mechanical Engineers, one Industrial Engineer, plus NDSU engineering interns
