Im just wondering if its complicated to recharge an AC in a 1984 camaro?? I wouldn;t think its to bad but, any tips or what kind to get? Thanks
up here they got these handy lil kits of R-tek comes with can of sealer,hoses for doing the job and a can of R-tek... R-134
Exactly.
But if it's still R12, you will need to have it converted over to R134.
Either that, or cash in your 401K so you can afford enough R12 to fill it.
o contre ....if it needs rechargin it already puked the contents out into the ozone ..now you need to seal the leak and stuff in 134
does your compressor get cold ..at all ??
if it just stays hot then its empty ....refer to my prvious post
if the compressor and lines get cold then you still have refridgerant in it ..but I am assuming that it is empty thats why you have no ac and are lookin for a fix
been there done that and bought the t-shirt
Ain't much you don't know, is there?
Take a pen and push on on of the schraeder valves on a service port and check for pressure like on a tire. If there's pressure-let it out (I didn't say that). Then, you'll need a couple adapters for the service ports to recharge it as 12 and 134 connectors are different. Most retrofit kits come complete with what you'll need. Only thing you don't know is if you have any leaks and if so how bad. You could do the H2 snow way and have cold air for 15 minutes. Should replace the high pressure cutout switch as they operate at different pressures but you can get by. My 2 cents-have someone evac it, pull vacuum to check for major leaks and if it's good recharge it with the correct amount as 134 amounts are 80% less than what 12 took. It shouldn't run you more than 125-150.
gee what is this a 12 step program ..buy the kit read the instructions....switchy not get any tail this weekend
LOL! Set the hook.
ya but ya still never got any azz LMAO
You want pics or descriptive explanations?
Take it to someone that knows, and get a quote. This is the best way.
