rebuild on shock???
the take aparts require nitrogen and oil
did it or is it blown?
most doo shocks can't replace the seals--- take apart just means you can oil and recharge
I send mine to a place called "gas shock repair" he cuts the shaft and replaces with (don't quote me) fox parts that allow seal replacement
i have not blown a shock seal since --2 seasons
You can replace seals in a HPG take apart. That's the purpose. And yes the HPG's require nitrogen and good clean oil.
What happens if you put them on upside down, My buddie has an 06 X as mine is our shocks are the same, but my warning stickers were upside down But the adjustment #'s were right side up. his are the oppisit. I took them off and unloaded the spring and they seem to want to be right. so i will try them the other way??
