Torsion spring spacer are a bad idea and waste of money, all they do is make you loose precious suspension travel. Look how the bump stops are right under the torsion springs.
They is a big bunch of different torsion springs available from Ski-Doo. Ask your dealer and he can retrieve the chart in his system. If he says he cannot, make him try harder. You do not need to follow the recommandation, the springs for SC-5M, cMotion, tMotion and rMotion all fit and you can figure out which one you want based on it's specs.
Personally I run the 503192104 / 503192105 which are 18% stiffer than stock but with 10 degrees less preload.
The 503192270 / 503192271 are 31% stiffer than stock and IMO, that's too much.
