Rear Suspension squeak
J
jsandgren10
I have a 2011 PRO RMK. I greased all the points on the rear skid but man when you push down on the rear bumper it squeaks bad. Almost sounds up at where the rear track shock bolts to the arm.
Anyone ever have this, any remedy?
Thanks.
When you said you greased all the point on the skid are you only referring to the grease zerks. The bushings need to be greased as well. I had the same squeak. Bushings greased and the squeak was gone.
So by the bushings you mean you removed the shock and did those bushings? Just want to make sure I understand correctly
Exactly true. Those bushings at both ends of the shocks (front and rear), and the arm below the rear shock, need to be greased. The squeak will go away.....voice of experience :)
Cheers!
