Rear Suspension Sag?
Iceman56
How much rear sag do you guys have? Mine looks like it's sagging a lot put a tape on it yesterday and it was over 2.5 inches measuring at the rear grab bar or rear part of the tunnel. 2.5 inches doesn't seem like much but looking at it sitting there it seems to be sitting lower then it should, and really feels like A LOT of wasted travel when grabbing ahold of it.
Mine is a 2014 163 with an Assault rear shock (stock spring) to keep front down with turbo. Is there any way to get some of the sag out?
Add some more preload to your rear track shock. Also ensure your track is tight. It is an uncoupled skid so it will sag more than a coupled...
Check the track tension. The track has probably stretched from new and this will cause the suspension to sag. Tighten it up a little and it'll be good.
Track tension is good... Do the springs soften up a little after they get broke in?
IMO don't worry about 2.5" of sag. More important is how the sled handles when your riding it not when it is sitting not being rode.
