hey i am going to have to tack the suspesion off the sled to weld a broken bracket by rear shock in the rear and was wondering what the easiest procedure was to tack it off..also can i remove this myself and how or do i need an extra hand ?
ZMAN THANX AS USSUAL FOR SOME GREAT INFO..i know the 4 main bolts but just want to do it right so which r the rear track adjusters?.Put rear off sled up on a stand. If you don't have a stand a rope or tie down hooked to the back bumper and tied to something on your roof works well.
If using a stand put blocks under the track so the suspension doesn't fall when you remove the bolts. If using a tiedown or a rope just barely lift the sled.
Loosen the rear track adjusters.
remove the rear bolts holding the suspension to the tunnel.
remove the two bolts holding the front of the suspension to the tunnel.
You can raise the back higher at this point for room to work. Then work the suspension out starting with the back. Once you have it clear of the track in the back you can pull it straight out.
will i have to drain the fluids with this side laying method or should i be fine left in ?An alternative method of getting it out is to tip the sled over on it's side once the suspension is loose from the tunnel. Then you can swing the back out away from the sled and lift it straight up.
