Rear rail support removal help.
odiermk
My rear rail support broke this weekend in the snowies and I can't get the broken part fed into the rail out. Any ideas? Heat? All that seems to be holding it together is a rivot and glue, correct me if I'm wrong.
Are you referring to the cast piece that connects the extruded running board to the tunnel? If so, a little heat will soften the glue after you have drilled the rivet out. I'm not sure the cast piece is available seperately so you may need to buy and replace the whole board assembly.
I was looking at the same page noticing the same thing that it is not listed seperately. If anyone has that part laying around would be interested in buying it or like you said maybe look for upgrade.
