Rear pivot arm 15 Pro
G
GtownRidah
Has anyone else noticed their rear pivot arm rubbing on one side against the rail? Mine is catching when I compress the suspension. Other side has about 3/16 clearance. Safe to assume they welded the vertical supports off center?
Saw something similar on my 2013 after letting a friend tie my sled on his trailer, too much side load on the rails tweaked something.
Both my 2013 and 2015 were centered and very smooth from new though.
Well I can see that happening. My sled has zero miles and only a 20min trailer ride home. I did take the rear apart put Redline to it. I thought that scissor point came apart hard. I see what the dealer has to say. Maybe I can get a new arm.
If it's not rubbing much you should be able to shim it enough to get some more clearance. They seem to have a lot of side to side play for whatever reason. Hard to make a call without pictures and not actually being there but if it's something you think just isnt right beyond normal sloppy production, I would make the dealer aware and let them replace the part or parts.
Dan
