Rear Bogie failure...?
2014 Pro w/163....Just breaking it in, only 16 miles.
Has anyone experienced a bogie wheel on the rear axle fail? Either stripping off the bearing or twisting and failing some how?
How about the top portion of your rail bending, just aft of the rear track shock scissor?
...just curious, mine did and I believe the wheel failed first then bound up the track which caused the rails to bend a bit.
In all my years of riding, jumping and dropping cornices, through the trees, over logs and stumps, this is the first time I've seen my rails bend or have a wheel twist and torque off the shaft.
Is Poo shaving weight and thinning the rails, much like the debacle of Doo when their drive shafts were twisting like pretzels in order to save weight?
...of course, the factory say's no dice on coverage by warranty.
