Looking for a little information.
1. What causes the Boggie bushings to fail on a 2016 Axys 163 with 800 miles, losing the Boggie caused one side of my Hi fax to prematurely wear out ?
2. should it be covered under the 3 year warranty, is it considered a wear item ?
3. Does anyone have a cut sheet of the rear assembly ?
4. Anyone have experience with aftermarket Boggie wheels and if so what do you recommend ?
I bought this sled as a Snow check and nothing but problems, seems it is always something.
1. Throttle block gave me issues, dealer replaced.
2. Lost RPM at 600 miles, got it back to 8150, won't run MDS weights any more, I did have success with them in the beginning pulling 8350, now using 10-64 with SLP pipe & can.
3. Low idle issues, finally corrected with a TPS adjustment.
4. Lower A arms fold up with a brush of a tree, changed out to Alt Impacts.
5. Had the Coolant hose replaced, had the Polaris Rub.
I do like the way it handles and loved the power it had the first 600 miles, I did put a new belt on the beginning of this season, so far I put 450 miles on it this year.
This is my 4th Polaris and by far had the most issues to date.
