J jTrue Member Feb 7, 2010 #1 Getting some 9" rear idler wheels, what size are the bearings for the rear axle? .75" or 1"? Thanks.
1 1Mike900 Well-known member Premium Member Feb 8, 2010 #3 For the rear axle 20MM or .787 dia. They are std. for a few, But 25MM seems to be the replacement shaft size from the aftermarket. Mike
J jTrue Member Feb 8, 2010 #4 Is this bearing p/n1604-847 or 3604-033? Read another post that says it is 25mm ID. Looking at these idler wheels. https://www.avid-products.com/store/ProdDet.cfm?ProdID=80
1 1Mike900 Well-known member Premium Member Feb 8, 2010 #5 Just put in 25 MM bearings and axles! Lot easier than machining wheels to accept 25 MM bearings! Mike
