Raw oil coming out of exhaust while running?
D
duc848
I was inthe garage last night aligning and adjusting my track. I had it running and reving it to turn the track over. I shut it of and there was a puddle of raw 2 stroke oil under the exhaust outlet. WTF? Where did it come from? I am confused. Any ideas?
did it look like this http://www.snowestonline.com/forum/showthread.php?t=187863
mine was spattering oil all over w/ a dribble out of the donut on the pipe. seems those seals need to tighten up with some heat or you can try the black silicone. i'm going to be checking my oil consumption as recommended and then see if i need to lean out the oil pump. some say there are cleaner burning oils out there also...
It isn't coming out of the y pipe. It was all over the floor in my garage from the actual xhaust outlet. It was unburnt oil.
they all blow oil out of the exhaust donut until brought up to full temp on the trail, starting them in the garage over the summer a couple of times builds oil in the pipe...
Right, my EGT's only get up to about 400*F or so in the garage at idle. Not enough heat to burn off the oil. They smoke and spit like crazy until hot enough to blow/burn it out. No worries unless your oil consumption on a ride is too much. Then you might have the infamous 09 sticking oil pump.
