They definately are, if you over tighten them you basically go through the soft intial rate and right into the 240# rate(stock TS is 200) so they get a bit harsh. But with that little bit of 180# inintial rate they are so plush! When I throw a leg over the bike everything just feels so much more lively then my old stuff. Doesn't feel like saddling up on a 2x4!I agree with Wheel House. Nice plush ride with better bottoming resistance. They seem sensitive to adjustment, too stiff and it will buck a little bit.
They look good too! White stuck out like a sore thumb on my set-up.
I think those springs might be the last and only mod I do to my TS kit before I send it down the road. I've pretty much come to the conclusion that there is no point sinking any more money into this kit, except for better springs.
M5
As I recall them they are 180 240 280. verifying with the guys from raptor as we speak.Nick, so the rates must be 180/210/240? Are there any plans for something slightly stiffer?
SO what's the conclusion???? PRO's vs Con's
got the rear spring changed no problem by pulling out the whole arm as you suggest.
the front one, arm came out without much problem but I've having issues getting the cross bar off the bottom shock mount.
Will be trying to heat it up a bit and hammering it out in a few hours. Other than that, this is fairly straight forward!
A little difficult to line things back up once putting the suspension back in, but not horrible. (yet! we'll see how the front goes back in, hehe)
thx!
did the upgrade. much better performance in chop but i thought they bottomed easier. haven't made any adjustments yet. install wasn't bad; about an hour.
What do you weigh? Lt or St? I am considering these but I don't want it to bottom. Have you stiffened the forks? Seems that transfers more weight to rear.
