raising idle
D
dmkhnr
Anybody know how to adjust the idle, as mine idles down so low that the lights and gauges won't stay lit up. It frequently dies as well while standing idle.
you need to have your throttle position sensor checked, sounds like its out of position...does the sled die when you put it in reverse?if it stays running, it could be that someone adjusted the idle rpm screw and you can try adjusting it back up to 1700 rpm...but if it dies or acts up at all when you hit the reverse button repeatedly, or runs funky on the hill you need to check the TPS setting.......
I set the tps with my ohm meter to .947. It was at 1.003
Can i just raise the throttle
Screw now?
add more boost or just keep it pinned;) maybe try raising the idle screw and then check the tps, has it done this since the turbo or is it a new concern??? does it idle smooth, maybe a vaccum leak somewhere???
It has been a low idle problem from the get-go, just with keeping the gauges lit up, reverse always works. It seems that the boondocker box is flooding out the bottom. I just got new numbers for this situation and will try it today. I thought that raising the idle a hair would be enough to burn the extra fuel off.
