R RMKrick Member Dec 19, 2010 #1 Had clutches worked on and put the 225 spring in. Now all it wants to do is rare up! What can i do or should i say adjust to get the front end under control..
R RMKrick Member Dec 19, 2010 #3 Come on 9 people somebody has had this problem. There isnt a sticky for this yet..
MORSNO Well-known member Lifetime Membership Dec 19, 2010 #4 Not quite sure what your question is??? Are you looking for more ski pressure and less lift? Suck up your front suspension limiter strap.
B BIGGDAWG Well-known member Dec 19, 2010 #5 which rear torsion springs do you have? stock ones will sag out causing too much transfer to rear. may want to go to the .375 springs
R RMKrick Member Dec 19, 2010 #6 Ya there stock wondered if I tightened the front one to much. Never had this problem until I put the front 225 spring on..
D Danbot Well-known member Dec 20, 2010 #9 How much pre-load did you put on the 225lb spring? I hated that spring until I backed off the pre-load to about 1/16"
R RMKrick Member Dec 22, 2010 #10 I cranked it pretty good at the start. Maybe i should try taking a few cranks off for a while first.
