Racin' Station 800 question
N
naz
New member
Well it's been a long time since I've been on Snowest... anyway. I have a 2006 M6 converted to Eric's M8 kit. I have tried many combinations of clutching.. took two years off and now have forgot what the recommended clutch set up was for 5k +. Anyone out there running this kit can give me a starting point for clutch, primary, secondary, helix / spring etc? Thanks for all your help as always!
fyi.. Im running the original Boondocker
Thanks,
Calvin
CALVIN!!!!! Where have you been? Good to see you postin again and to know you are kickin!
Single pipe set up
69 Gram primary weights
Speedwerx Maroon/White spring
36 degree helix in secondary with Cat platinum spring (also the team conversion with the Red/White spring works good too)
  • Like
Reactions: naz
Thanks Eric, I tried to call you but you were busy...then me... etc. Ok, great I will get my parts together and ensure I've got that setup. If not, I'll call you to order. Thanks Eric!
Calvin
Eric, I have the stock pipe with outlet not enlarged, will that work or should I get that mod for the pipe?
