2011 M-8 162 SNO-PRO I out it in reverse on flat ground yesterday and it started making a grinding noise that sounded like it was coming from the diamond drive and wasn't moving very well. I put it in forward and same thing. I turned it off and on and went in forward with no problems.
Rode all day with no symptoms, but it started again at the end of the day both time after I put it in reverse on flat ground. I drained the diamond drive and pulled the cover expecting to find a bad bearing or missing teeth.
Everything looked good and the bearings were fine. The last owner had just installed a new track so I thought about ratcheting, but I climbed hard all day with no ratcheting and I've never had a sled ratchet on level ground and that track doesn't look to be very loose.
Any ideas would be greatly appreciated.
