Racer's Edge has come out with an incredible solution for your rear suspension. Don't want to shell out $3000-$6000 for an m-10. Below are some pictures of their little set up. It's basically there way of putting out a more affordable option then the m-10. What's included is below
-Double Adjustable Coil Over Shock (compression and rebound) just got back from their shop and let me tell you that this setup is going to be unreal!!
-Chromoly swing arm
-billet brackets
-UHMN slider blocks
-Aluminum tunnel stiffener's
-Stainless Steel hardward
-Aluminum cross shaft
I've got a couple of pictures with both a cat skid and skidoo skid just to show what they involve and look like. If you want any more info, pm me, or you can contact Darryl Baker at 403-254-8686
cat and yammi are 1995.00 canadian
skidoo is 2195 canadian.
You can put a deposit in with Darryl to get in line for this.
![racersedgem10 002.jpg racersedgem10 002.jpg](https://www.snowest.com/forum/data/attachments/31/31159-c23520d4e7cbe379dd0e58ef1e9d6791.jpg)
-Chromoly swing arm
-billet brackets
-UHMN slider blocks
![racersedgem10 006.jpg racersedgem10 006.jpg](https://www.snowest.com/forum/data/attachments/31/31127-3ef8417b9edb709f3541fc84cca41688.jpg)
![racersedgem10 013.jpg racersedgem10 013.jpg](https://www.snowest.com/forum/data/attachments/31/31138-07e40be0add9d9a253206dcdf415413b.jpg)
![racersedgem10 017.jpg racersedgem10 017.jpg](https://www.snowest.com/forum/data/attachments/31/31152-b1ec2a205876874960969bc82736105d.jpg)
