race gas
What are guys paying for it also,and where are they getting it from,the best price,USA and Canada?All these two stroke turbo's require quality fuel,so maybe it will bring the price down due to large amounts being utilized,wouldn't that be nice?
what is it going in . many uses for many fuels
mike
I've got one for you? I'm running N2O for the first time on a 700 poo. was told to mix a gal or two per tank what's the best type of race gas for that?
Do you have any experience with race gas concentrates? Might be easier to get and take along for me.
Doubt that most places will see $$$$$ and probably make it more available but not cheaper.
Wishful thinking though!!!
Gas
Just one thing not to forget. If you use a higher octane than your compression calls for, you will loose power. A sled that calls for 91 oct, will be slower if you use 110. Save your money.
trick, sunoco, klotz
your sled
my sled huh ? well i run 114 trick fuel up to 14 psi same with 114 sunoco sepreme . then for 15-18 i ran 118 klotz race fuel but cant afford the klotz this season 10+$ a gallon . the trick i buy is 5.25$ a gallon . the sunoco supreme is 7.50 a gallon . sled seems to run a bit smoother on sunoco then the trick at 14psi . but have never had any issues with the trick . that is what im running this season !!!!!!!!!!
mike:D
Well said!!!
On that note I run VP Racing U2 at 60/40 ratio with pump gas (60% pump gas). You really don't want to know how much I pay 5 for gallons of it. Look at going to a concentrate might be cheaper.
Oh, and just becuz some is good, more is not always better. Never blend nitromethane....learned that lesson the hard way!! :D
i run a mix of renegade 110 with premium.... i think its right around 6 bucks a gallon now
