race gas concentrate
M
madmini660
has anyone ever messed with race gas concentrate and what did they think any info would be awesome have bd rg turbo m8 that has never had anythink but 110 race gas in it but geting old buying lots of race gas just looking at other options for this year just dont wont to do a motor in mid season thanks
i ride frome 6- 8 going to run av gas this year to 12lbs and for those days when the snow was deep I'd like to go to 14lbs I was just wonting to know if I could add some race gas concentrate to av gas to run that 14lbs safe thanks
I am of the beliefe that there is no substitue to real formulated gasoline. I would stay as far from it as possible; with a 2 stroker especialy. Trying to save a buck up front will most likely cost a whole lot more down the road. I ride from 6-8000 and I will be running AV gas at 8-9 psi this winter. Watch your A/F or egt and see where the av gets you. If your injectors are maxed out then a higher octane fuel is needed. Try mixing race and AV from there and see where you end up for mix percentage at your desired boost level.
who's kit are you running is it rg or pg I've got a bd rg it's got 4injectors if that really matters just wonted to know if the two fuels where conpatible or if it would even work thanks
