So on my 09 700 I am thinking about changing spring colors next season.
What I have now is a black spring labeled as a 140/330.
What I am thinking is that I would like to put in a black/green 120/340 spring to lower my engagement RPM a little bit.
What I am wondering is - what will the slightly higher finish rate do for me?
Throughout this season I have had a little bit of belt squeal at idle when it gets warm which I am attributing to the belt deflection being just a touch on the tight side, but I have also noticed at times that it will squeal at slow moving speeds as well.... something I would not think would be noticeable after engagement with simply running the belt too tight??? Could the current spring be too stiff at slow speeds?
So far I have 600 miles on the belt and it still looks good, despite getting hotter than the surface of the sun when riding hard
Thanks for any input you might have
