Quick drive pulley spreader tool?
I
icr
I'm looking for the tool to install quick drive belts, it looked like a turn buckle with a C on each end, you placed it between the pulleys with the belt on and it spread them enough to put them back on the shafts. Anyone know what I'm talking about and where to find it?
I've only ever used alignment studs. That's an interesting idea though. Does anyone know the centre to centre distance and the thread size?
I think I could make that at work
Come to think of it. The same could be accomplished with a piece or two of ready rod and some custom made nuts. Basically the same concept as a telepost.
All you would have to do is weld a washer set the right depth to allow you to hold the pulleys apart while still allowing you to slide the pulleys on to the shaft
I might just build this at work today if anyone can get me some rough measurements and a thread size or the shaft sizes
Come to think of it in might just go to the brothers wrecking yard and cut up a couple old drivers at the right length and use the exact same splined shafts and just slide it from one shaft to the next
Kurts performance sells the line up studs. they work pretty slick.
http://snowest.com/forum/forum.vb/picture.php?albumid=3532&pictureid=34082
Simply take the sprockets off or at least that's how I do it. Then place the zip ties where the red line is shown. Pull it tight until it holds its shape on the belts and then it will line up on the shafts easily. I spent hours fighting it until I tried this. Once I did this had the sprockets and belt on in minutes
that's it yeager got it just right , there is also a youtube video, be assured it works perfect.
makes it very easy to install. I always start the lower gear first, then get the upper close and then wiggle the brake rotor to get it to slide on. Eric
I just received the Armstrong Tool and it is great quality workmanship and Doug Armstrong can be reached by going on line Young Bigger@yahoo.com I think the phone # is there.
gtwitch in wyoming
