This is NOT a bashing Thread, but I want opinions/facts/help please.
My QD belt went last Sunday...I am from MA and ride up in NH and ME. Luckily the thing went not far from where we could tow it to a road and avoid a serious situation.
I was hitting an off trail honey spot and riding through 4' of powder...Yep, we're having a mint winter out there.
The next thing I know the track appears to catch on a branch, then again b/c it made a ratchet kinda noise/feeling, and then all of a sudden ZEEEEEEEEEEE and the smell of burnt rubber and no more forward momentum.
1 hr later, after trying to change the QD belt, which had ALL the ribs except like 4 gone, we gave up and towed it out with my buddy's 11' Pro RMK...which was a $hit show b/c we had to turn the sled around from an uphill to a down hill and pull it through both our up hill trenches...needless to say it sucked...and I barely had a brake of any kind so it's not the most confidence inspiring feeling.
So things learned and things I would like to know from you guys out west:
Learned: Despite having a spare QD Belt, with instructions, and Happy Face Alignment tools, we both found out NONE of those instructions work for $hit out in the woods. We literally reefed on both cogs like our lives depended on it and I think the top one moved a 1/16th of an inch....
Needed to know and now have Learned: ignore all instructions and either use a branch or keep at least a 12" pry bar and work the cogs off very carefully from as many angles as you can.
Learned: Despite having a few cogs left, and NOT cutting or breaking the belt...the sled WILL NOT GO 1' under its own power with a stripped QD belt so POO is full of $hit in that department b/c I would have cut the belt to try and more easily work off the cogs, but I was thinking "don't do that b/c at least I will be able to ride it very slowly home."
Learned: At my dealer my buddy used a small pry bar to work off both cogs w/the belt still attached, then we screwed in the Happy Face alignment tools, and with a 18'' pry bar over his shoulder and the face inside one of the holes on the top cog he worked that top cog on very slowly after putting the bottom cog on about a 1/4"....but he could still NOT get it on past about a 1/4" up top so out came a huger Socket that was larger on its inner diameter than the jack shaft's outer diameter and with a mallet he "Tapped" (LOL) the cog onto the shaft...and only then did it go on at all....then it was more of that and finally the top one was on. The bottom cog was then tapped on as well and then he went around to the other side and spun the drive belt which self centered the QD belt onto the bottom cog...this was close to an hour...on a LIFT.
So still need to know:
What are you guys out west seeing after 1000/2000/3000 miles with these QD belts?
HTF are you changing them on the trails/in the woods?
I was under the impression these things only went on a G-Out from jumping or hitting the air, and then whaling the throttle the instant you hit the snow/ground...but I was simply riding in powder and then beginning a climb...and NOTHING was loose or out of whack at all....
I appreciate whatever you guys can offer for Advice, Experience, etc. Thanks.
![Face Icon Small Happy :face-icon-small-hap :face-icon-small-hap](https://www.snowest.com/forum/images/smilies/old/face-icon-small-happy.gif)
