Thats a big N.O. They changed the length of the belt, axys belt is 2 teeth longer. Eric
Eric, u noted on the other topic that we could use axys belts on pro gears...am i misunderstanding somthing?
Kind of. Both statements I made are correct.... You cant run a quick drive belt from a 13-15 pro on an Axys, But you can run 13-15 pro gears on an axys with the stock axys belt.
The axys belt is 2 teeth longer, but the Center to Center distance from the jack shaft to drive shaft also changed. Eric
Eric, do u know what the gearing is on kurts kit for the axys?
2.37.... thats very close to the factory gearing on the 3" chain case sleds, they are 2.32 Eric
Eric, wat was the differance from 13 to 14 pro pulleys? I may have a chance to get some 13 pulleys for my axys.
Thanks Eric. Are the belts from the 13s interchangeable from 600-800 RMK. Selling my 13 800 but keeping sons 13 600 and have a spare from the 800
