So is the chain touching the track okay? I assume it's normal. The chain tension from the engine sprocket is tight like the instructions told me to do.
I have blankets and a termobob and temp sensor, plan to only rip around above 170. Honestly my biggest concern is the battery/starter system failing. I got an AGM or gel battery (can't remember which) for it so hopefully no failures.Chain rubbing on the track? my experience : its not an issue, your bike and your kit mine rubbed, so I notched my track, didn't notice any loss of traction and couldn't tell my track turned easier. Later put a big track on my Yamaha back then........really rubbed big time, again cut the track notch, not sure it was necessary.
Oil changes in your bike/ all bikes, in the snow is all about heat management, if your water temps are all over the place and low in deep snow, then best to change oil every cold ride. If you upgrade to engine covers and heat exchangers so the bike runs 170 and up ALL the time, you will find clean clean non contaminated oil after 3 or 4 rides. Oil will stay far cleaner than riding your bike in the dirt, which says a lot about how much dirt passes our K and N filters in summer riding.
When we started sno bike'n, totally ignorant of whats up, we had white foam in our oil after 3 hrs of cold morning riding, we had friends Suzuki and Kaw go down with engine failure from water in the oil, was all unnecessary if we had got our head out of our, you know, and thought this thing through.
Yes you can bolt a kit to a bike and take a ride, but if you stay at it and ride in all conditions, then some serious shop time is in order.
