question on nytro
how do you clear the codes on the nytro? Thanks james
Push and hold reset on the display. If that does not work you need to go into diagnostic mode and clear the codes.
Disconnect the power source to the fuel pump. Push "reset" and "select" at the same time then turn the key but do not start the sled , hold the buttons down together for 8 seconds until "diag" comes up. Let them go then push the together for another 2 seconds with the key left on. "01" should come up. Scroll up or down through the codes with the Select or Reset button.
Scroll until you get the following 2 codes.
61
Malfunction history code
display
• Displays the code numbers of past malfunctions (i.e., a
code number of a malfunction that occurred once and
which has been corrected).
• If more than one code number is detected, the display
alternates every 2 seconds to show all the detected
code numbers. When all code numbers are shown, the
display repeats the same process.
12 ~ 85
(00) Displays when there is no
malfunction.
62
erasure
• Displays the total number of codes that are being
detected through self diagnosis and the fault codes in
the past history.
• Erases only the history codes when the grip warmer
side of the grip/thumb warmer adjustment switch is
pushed.
00 ~ 23
malfunction.
Hope this helps you.
Motleyone
Grip warmer-open or closed circuit.
oh, i bought cr racing bars and risers but i just cut off the hand warmers because they are on order but i want to get started the install. That would explan the code but my head light and tail lights don't work ether would that have something to do with the code and my handgribs not pluged in? thanks alot for the help i thank you
