The new crank kit is a good deal. It has an enlarged 32mm PTO end on it for added strength, comes with a brand new clutch, and a brand new 3211115 belt.
Babbits has them listed for $880
http://www.babbittsonline.com/pages/parts/viewbybrand/14/Polaris.aspx
you do not haved to have them line bored it is just indy dan recommends it to get bearing tollerances right
I sent three of the new cranks to Indy Dan this fall.For $500 he will true the cases and add another bearing to the pto end.Give him a call.He's a h3ll of a nice guy and will treat you right.
Yes.I sent him the complete bottom ends and the new cranks.He disassembled,cleaned replaced oil-water pump seals,trued cases,added third bearing and machined new groove for lock ring on the new bearing,and re-assembled.He calls this his Torque Master 1.
I think he probably has the new cranks in stock.
You do have to have your case halves line-bored for the Polaris crank right?
Just curious one of my ridin' buddies here in v-town was asking me about that for his 9 ....
This isn't necessarily true. It depends on whether your cases are machined correctly to start with. For some, it may be mandatory.
