Over fueling on the EFI bikes from low engine temps.
Aluminum block + snow = cold motor. You have to cover it... a stat will help build temps back up quicker but it doesn't do much to stop the steep drop during pow days. Like other have said you can literally watch your temp gauge dive from 180 to 120 in about 20 seconds when blowing through deep champagne. FI bikes will compensate the cold air temps with more fuel and combine the lack of heat for the rings to properly seal and you get blowby... fuel in the oil. Use an engine cover + stat + temp gauge if you really want to keep the bike running well and fuel out of your oil.
I hear what your saying, It wont overfuel like an auto choke engine will however the temp sensor which monitors fresh inlet air will richen mixture, surely a map can correct that and prevent overfueling due to cold inlet air?, and there is no exhaust temp sensor on the race bikes, trying to get to the root of the problem instead of masking the real issue. many thermostats have a huge bypass hole that always circulates some water through the radiators, some almost shut off completely, looking into that as well,I hear about many covering the radiator with plastic, That is a bandaid and means the t stat is allowing too much flow all the time thoughts?
I know the avid stat is a complete shut off... That is what I use... Still the powder does suck the warmth out.
Sent from my iPad using Tapatalk HD
how much cover is needed if the t stat really closes ,have any pics or suggestions? putting foam between the skid plate and bottom of cases will keep cold snow from getting in cooling down oil as one precaution?
I've been doing the closed cell foam between skid plate and sump with no shielding for the last few seasons... it helps but it is not enough for deep powder.
So who's running any of the shrouds available out there? (not homemade) The ones i can find are moto 365, PST on thermobob's website, and the SXS snowshed plate.
None of the websites have great pictures. So far i like the look of the pst because from what I can tell, it looks easy and quick to remove. Anyone with real world experience want to chime in?
Moto365 and SXS are the same. What bike do you have? I'll try to get some pictures of it for you.
sx450
