Is it worth buying the tools and learning to do my own fork rebuilds? Seems like everyone has “a guy” and my “guy” is retiring.
$100 worth of tools and oil. Use it once and it pays for itself. Im not messing with valving or anything. just updates on the AER forks, oil changes and seal replacements.
Do it!
with a few articles off racetech on valving, midvalve float, and spring rates you can do that too. A parts cleaner is a nice to have for it as well, but yeah - go for it.
That does sound like a pain. Any recommendation on a brand for seals? From reading looks like the “high protection” SKF seals are pretty popular.The air chamber is a pain in the butt. You need a special billet aluminum clamp to hold the air chamber while you torch and break it open. You'll have to spend a few hundred on that... Racetech again, or a machinist. I think it's 30mm...
I run KTM AER forks. I use a 2x4. drilled a 1 1/8"? (i think) hole in it. then cut it in half length wise. Presto. lock it in a vice. I use a heat gun. a map torch would work too. Just don't get to hot. I use SKF seals as thats what all the pro shops use. Prolly a reason why they use them. The only special tool I bought was a 48mm seal driver. Basic tools, and a having a good large adjustable wrench as well as a heat source and you should be fine. Once again watch a few videos and you will see what you need/ dont need to waste money on.
Thanks for the info on that ill hold off on the bushings for now. Bikes only got 18 hours on it.The bushings seem to last long long time. I have a trillion billion 300 thou um... miles on mine and only see them go bad if they were run with no oil from a really bad seal leak. Sometimes when you jack hammer the tubes apart it buggers up the edge of the Teflon on the bushings a bit but I just cut off any high spots and they work as good as new. The surface area of the Teflon seems un important as they actually make them with smaller surface area since they did in the good old days of horrible ktm forks...
I really don't know but my cycra probend with the expandable fittings uses the same bolt size and thread that I use on a set of C3 bars and a set of Protaper bars.Thanks for the info on that ill hold off on the bushings for now. Bikes only got 18 hours on it.
Off topic question, do handlebar manufactures have a standard thread pattern for pre-tapped bar ends? I kept the pro bends off my last bike and id like to re use them. I ran a thermobob w/ Timbersled heated bars last season. Id like to try the C3 stat & bars on this one.
